Old 07-27-2008, 06:56 PM
Mark Deluca Mark Deluca is offline
Cobra Make, Engine: Midstates, 428SCJ
Thanks eveyone. Rick I believed I sent you a replay but if you did not get it I will repeat it. I currently am having an alumium raidator made. according to the shop owner the size should handle up to 650hp. I did find out that the electric fan is only rated at 1700cfm. again shop owner states that should be enough to handle cooling FE. He did talk about cooling the engine compartment. Rick I stopped at a marine store bought a 3" attwood bilge pump blower. My concern is to vent it out the side lovers it would need to mounted close to them. This would put the plastic blower above the headers. It you did this Rick did you have a problem with header heat melting or worping the fan? Do you think that wrapping the headers would help? Thanks again all.
Mark
