  #35 (permalink)
Old 07-28-2008, 09:07 PM
wanab5150's Avatar
wanab5150 wanab5150 is offline
Cobra Make, Engine: Superformance #2769 Roush 427R Dart Block
When I switched out the above pads I didn't think I would be switching back. I just assumed I would like the BP-10's. You know what happens when you assume!!!
Now that I have switched back, the brakes are as they were before...."pretty good", but it seems that the fronts may be sticking on easy stops....like when you roll up to a stop sign slowly, they will slightly stick and stay that way until I push hard on the pedal, then they will completely free up...
Since I didn't think I was going to use the pads again I didn't mark them and just put them back in with no idea which caliper the came out of. They only had 1500 miles on them.
Is it possible they will self center and wear in in a few hundred miles, or is should I should replace them even with only the 1500 miles on them? The car stops exactly as it did before I changed them. ****!
Tom
I miss my Tazer
