I'm in agreement with a couple these responses... One, the accelerator pump cam may not be agressive enough to provide enough fuel when the throttle snaps open quickly. This will cause an over lean condition when the throttle is suddenly snapped open...too much air, not enough fuel...and a noticeable nose drop during hard acceleration. Holley sells a series of plastic cams, each with a different color to represent a different amount of gas injected via the squirters. Easy to replace, and certainly cheap enough. But, before you do that...check to make sure your squirters are working properly...like WTM442 suggested. I've seen much the same problem as you described occur when the screw plunger on the accel pump arm just wasn't long enough to fully depress the diaphram. A simple adjustment to the screw length was all that was needed.
Conversely, if you're going too rich when snapping open the throttle, you may be getting TOO much gas through the squirters....you may need to go to a less aggressive accel pump cam. If this is the case, you're going too rich...which, again could cause a noticeable bog under hard acceleration. I think the Holley kits come with 5 different plastic cams...Summit and Jegs both carry them.
And...Two.... I've never been a fan of vacuum operated secondaries. I'm running a Jet Performance tuned Holley 750 cfm 4150 series...their famous "Double Pumper"...no choke, mechanical secondaries. I've been very pleased with performance, both for street and track use. I can open the mechanical throttle linkage and butterflies by hand and verify that all four throttle plates are perfectly verticle when running WFO!!!
But...the best way to tell without wasting a lot of time, money, and effort buying and swapping carburetor parts is to go to a good chassis dyno operator and pay them for their diagnostic time. You'll be real glad you did...
PS...Here ya go....click the link and look at part number HLY-20-12... an assortment of 8 different cams for $21.95, plus more on the page to help confuse ya...
http://store.summitracing.com/egnsea...+115&y=13&x=22
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
