Old 07-30-2008, 03:17 PM
cobraduke cobraduke is offline
Cobra Make, Engine: SOLD Excalibur, '94-'95 5.0 EFI, Edelbrock heads, E303 cam, 1.7RR, Cobra intake, 24lb injectors, 93 cobra ECU, 65mm TB, hi flow cats.
Default Switches and Fan
Don't think the aux switch is wired to anything. Probably could use it for driving lights or ?
The computer controls the fan based on temp. I had to install a separate fan controller when I found mine had a '93 cobra computer swapped in (with some wiring changes also required). The earlier Ford computers (pre '94) did not control the fan as it was mechanical, not electric.
Mike
