Old 07-31-2008, 04:59 AM
sideshow sideshow is offline
we finally gotcorrect engine loom from holden
i guess they didnt tell u how complicated the tip tronic set is
they sent u the l76 auto harness its usesles on an l98 titronic
the tip tronic works thru the bcm and then the bcm talks to the pim
then the pim talks to the engine ecu
the tip tornic gbox has the auto ecu inside of the gbox
we spoke to holden and u cannot buy a new bcm for the ve at this stage
and the bcm has very fancy plugs on it so i guess we willneed to buy the dash harness which has the bcm plugs
but i pressume it wont be available to buy yet either
another problem holden didnt tell u is that the ve will not start if the factory stereo is not there so the enigne ecu needs to have security disabled
but we are not sure what tune the guys at holden put in the ecu
like 99% of people out there guys at holden have no idea and did not do their research properly and atleast should have told u these things
but not to worry we are slowly getting thru this and asking alot of questions to our contacts at our holden shop and will be looking for a crashed ve to try get the parts that holden cant supply yet
another thing is the engine and auto has to be all plugged in together then a factory tune be flashed to both the auto and the engine ecu then the enine ecu needs to have the security turned off
so the ecu they supplied was a waste of time removing security cause it might have to be done again if we have to flash both ecus with a holden tune
anyway yr in better hands then those guys at holden down in melb where u got enigne
so hope to have all the stuff in next few months
so not to worry
my website
www.sideshowsperformancewiring.com.au
