Old 08-01-2008, 06:46 AM
elric elric is offline
Cobra Make, Engine: ERA #726 427 SOHC
Default Reuben Cain
Is this on a Cammer or Wedge engine? If Cammer make sure rocker arm has oil feed holes from shaft hole to roller side of arm. Also, check the oil feed hole from cylinder head to rocker shaft; usually they are almost completely covered and you will need to drill new holes in the correct position.
Steve
