Old 08-01-2008, 12:24 PM
RedCSX1's Avatar
RedCSX1 RedCSX1 is offline
Cobra Make, Engine: Shelby CSX 4766 (Vegas Built) with 482 Aluminum Pond motor
Go with Blue Thunder heads if you can afford it. Really good quality castings. May have to run Tand D rockers setup but it will be sweet with that block. If you are going for stock stroke then stay with the Ford rods an crank with ARP bolts and nuts. Polish the rod beams and balance. Go with a 242-245 /600 cam range. Also run Blue Thunder ported dual plane intake with the setup.
Morgan LeBlanc
Fresno CA
