Old 08-01-2008, 05:13 PM
Jac Mac's Avatar
Jac Mac Jac Mac is offline
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Smile
Originally Posted by jeffsFE View Post
Have you guys ever looked at the cams in these motors before you put in the cam spacer on,it seems like the cam sits back to far the lifters to ride on the cam lubes correctly.
Cam lobes should NOT be centered in lifter bores, they need to be slightly offset in order to promote lifter rotation. That said there are two types of timing gear sets for FE, one with thrust button that runs via spring against timing cover & later type that utilise a thrust plate in similar fashion to small block fords. Make sureyou have the correct set for your application.
Jac Mac
