Old 08-05-2008, 11:53 AM
madmaxx madmaxx is offline
May have made progress on the remote reservoir also. I knew I had tightened it in the past and when I tightened again it was loose. If you bottom the reservoir out on the holder and tighten the clamp it will tighten. If you slowly rotate the reservoir or over normal driving it vibrates it slips up about 3/16" and then it is loose again and leakes. The key is get about 3/16" gap from the reservoir and holder and tighten. There must be a small radius at the bottom of the holder and once it slips above that the clamp loosens. We shall see.
