Old 08-06-2008, 06:39 PM
Smike740 Smike740 is offline
Cobra Make, Engine: CR II 351W
Hey DV double check the mounts. I put my kit together in 2003, at that time you used 2 of the same side engine mounts. For whatever reason Don made the weldments to use the same mount on both sides. If you have a right/ left set it should be no problem you just need to move the mount locating stud (not the stud with the nut) so it fits into the CR II supplier weldment. I don't remember if my mounts were from prothane or energy suspension but in either case the hole was already there to move the stud to. Hope this makes sence.
Thanks,
Mike
