Boys
Snaken is back running, no more
oil leaks from the custom individual throttle body intake manifold.
BUT you have to make changes, so I fitted an
oil cooler
The out come ............... suddenly I have less
oil pressure. WHY would that be.
I am running from block through filter down to cooler and back to the engine. Running same oil, gauge is manual ( Smiths) but gone from 50 ish to 40 ish ???
Got 30 lbs on crank but only 40 ish on 1500 rpm. Only just got it fired up still on axle stands will give it a rev up in the morning, but anyone got ant ideas
