Old 08-08-2008, 10:52 AM
Slick61's Avatar
Slick61 Slick61 is offline
Cobra Make, Engine: BDR #89, KCR aluminum 427 windsor
Originally Posted by native1 View Post
I thought the new pipes/headers would bring back some of the low end torque I lost due to the 950cfm carb. I was talked into the carb by local race shop paid 1000 dollars. Performs much smoother than the 770 street avenger it came with however, not as snappy. Should have done 750 or 850 cfm carb instead.
... funny you should mention that. My engine was originally running a DaVinci 950 cfm carb, but was then later switched to a 770 street avenger for better streetability. Tuning is a big factor, though... I dyno-tuned the car last fall & with the 770 carb on, the power/torque was nearly identical to running the 950 cfm carb, once it was re-jetted & properly dialed-in. Horsepower/torque losses were maybe 3-5 hp/tq MAX.
R. Smith
Santa Clarita, CA
BDR #89- KCR aluminum 427 windsor, TKO-600
