Old 08-09-2008, 09:10 AM
289ACE's Avatar
289ACE 289ACE is offline
Cobra Make, Engine: 2 AC Aces, 1 w/289, 1 w/TBD
Kris, Thanks for the pictures. I am aware that most worm and sector cars that are converted use a rack on the rear, but my car also came with an extra a-frame that may be for a rack and pinion set up. I am trying to determine if the extra a-frame is really for rack and pinion, and if so, how much work would be needed to convert the rest of the suspension over. I figured in this case a picture would probably be the easiest way to see all the parts and the setup. I may just stick with the original set up, convert to a rear rack, or change to a Cobra set up depending on how much work is needed for each.
Jay
