Old 08-09-2008, 07:49 PM
SuperHart's Avatar
SuperHart SuperHart is offline
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
I have a 351W with oil cooler, high volume oil pump, -10 lines and a thermostatic sandwich adapter. Using 10-40 oil I run 55 lbs pressure until the thermostat on the oil cooler opens, then the pressure drops to 50 lbs. Believe it or not, I have found some pressure differences depending on which oil filter I use. Remember also that oil viscosity can also affect oil pressure. In my opinion, 45 lbs in a warm engine ain't bad so I would leave well enough alone. If you are not running a thermostat, please do yourself a favor and install one.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
