Old 08-10-2008, 10:16 AM
wtm442's Avatar
wtm442 wtm442 is offline
Beam Me Up Scottie
Your battery is probably going bad, and it sounds like you also have some grounding issues. Remove the ground straps/wires, check them for corrosion, clean and replace.
You probably should replace the voltage regulator. The alternator output should be a max of about 15V when it is charging the battery.
I hate electrical problems! Good Luck!
Warren
