Old 08-11-2008, 06:46 AM
strictlypersonl strictlypersonl is offline
It seems to me that there are two problems here: Bad ride, which can only be fixed with a spring/damper change, and a tire-clearance problem which can only properly be fixed with a wheel offset/width change or a tire change. Changing the ride height to "fix" the latter problem puts you in the position of changing the basic suspension geometry, usually to its detriment.
