Old 08-11-2008, 09:30 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Don,
First you have a beautiful car.
I went back and looked at your photo gallery and you are not running anything so wide you would be creating your own problem. It looks as though you are probably running some 8" wide rims all the way around with maybe some 235 X 15 front and 255 X 15 rear.
Your offset/Back Space doesn't seem to be creating your problem either. I assumed you were talking about the rear tires rubbing on the outside of the tire and NOT the inside. I think the Hal (QA-1) shocks will solve your problem if you just need to pick the rearend up a little. Your Mustange springs JUST may be to soft for your car.
Clois
"Let's roll"
"Be part of Something Good
