Thread: 351W rockers.
Old 08-11-2008, 04:12 PM
VINCENT RUDI's Avatar
VINCENT RUDI VINCENT RUDI is offline
Cobra Make, Engine: ANTIQUE AND COLLECTABLEFORD 460
You Do Not Need To Readjust Rockers On A Hydrolic Lifter Cam If The Install Was Done Properly.first Make Sure The Flat Part Of The Rocker Shaft Is Facing Up So The Nut Sits Flush, Simple Mistake Then Adjust The Rocker Arm A 1/2 Turn Passed Zero Lash. Mark The Top Of Your Set Screws, People Look At Me Like Im Nuts When I Do That, But Im Not The One With The Problems In The End. Also Check Your Clearences Between Your Rocker Arms And Your Springs That Will Also Pose A Problem. Also Check Your Push Rod Sizes Sometimes The Exhausts Are Bigger Than The Intakes Or Vise Versa Or The Size Of The Pushrod Is To Short And The Rocker Arm Has To Much Travel. Good Luck
