Old 08-13-2008, 07:11 AM
Mac VABCH's Avatar
Mac VABCH Mac VABCH is offline
Cobra Make, Engine: BDR #250
Hogster,
I have the same engine that you do, but since my car is track use only I am going with AFR 205's with as big a cam that will work. But currently it has Victor Junior steel heads with 2.02 intake and 1.60 exhaust valves and a E303 cam. It makes 340hp at the wheels with a very flat torque curve. You will be very happy with it. I will warn you about the Mass Flo. It does need to be tuned on a dyno after the car in up and running. Chis at Mass Flo does put a chip in the computer and "tunes" for you engine size but I have gain 20 hp over the initial tune with my tune at the controls. Its was also very rich initially...But once its dialed in its is wonderful. Two years after I had the car tune I went back to check on the A/F ratio and it was within 2 hp of before...Mac
