Thread: how much HP
Old 08-13-2008, 10:03 PM
Slick61's Avatar
Slick61 Slick61 is offline
Cobra Make, Engine: BDR #89, KCR aluminum 427 windsor
Originally Posted by Madmiles442 View Post
Solid mounts will shake your teeth out.
...pish... I've got a KCR aluminum 427w in my Backdraft with solid mounts... it's not bad at all. The only time it's really noticeable is at idle. Mine puts out approx. 612 hp/tq at the crank & 458 hp/tq at the wheels. With the aluminum flywheel, it spools up fast... almost faster than you can shift (my TKO-600 does not like to be speed-shifted)- so you learn quickly to go easy on the loud pedal in the first few gears. The pucker factor comes into play when you open up the secondaries... yee ha!
R. Smith
Santa Clarita, CA
BDR #89- KCR aluminum 427 windsor, TKO-600
