Old 08-14-2008, 12:44 AM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
Hi Bernie,
before massaging the emulsion tube I would try a smaller air corrector jet. The smallest is a 0.80mm size. You should try that first.
You can also try a slightly larger main jet if that is not enough.
Modifying the F14 emulsion would imply drilling the inside well of the tube with a 3mm drill to a depth of 30mm and drilling 1mm lateral holes at about 28mm from the top. It would be a matter of drilling first one, then two and up to four holes and testing each time. The center hole can be plugged with a 3mm brass plug any time again and the tube would be back to original again.
I am glad to hear that my personal feeling about the good response of the F14 tubes has been confirmed on a dyno.
I am still putting my new engine together and have 8 42mm Venturis waiting to be installed. Will see how they work.
Nothing sounds better than a Cobra in a Tunnel !
