Thread: Recent Doings
Old 08-16-2008, 07:31 AM
LoBelly's Avatar
LoBelly LoBelly is offline
Default Recent Doings
Winter is a good time to get some odd jobs out of the way.
After the upgrade to a fresh 347 from a very tired 289 the open diff was having a bit of a conniption. So after a lot of research confirming that I can put Dana44 bits in my Salisbury casing I find that that the cost of importing all the bits I want is only marginally less than having the local Jag guy redo the diff (although some of his parts are second hand). The local guy uses his own secret formula of bearings and bits and reckons he's been racing on one diff for 10 years...
Here my brother is adjusting the handbrake prior to us refitting the assembly, apparently you're supposed to put split pins in to stop the hand brake adjustment unwinding - who knew? As part of the deal a finned aluminium cover is provided
Along with the 347 came a higher intake manifold which squashed the space available for an air filter - even after adding a bigger air scoop. Consequently the choke horn on the carbie was almost up against the top of the air-filter lid.
After some subtle massaging of the choke horn we were able to create a little extra room for air flow.
Lastly, since the first time I saw those vintage decals I've really liked them, so I grabbed a set. (the camera on my mobile doesn't cope with the yellow colour of the car in the sunlight)
LoBelly
