Old 08-16-2008, 09:39 AM
Dan Semko's Avatar
Dan Semko Dan Semko is offline
Hoosier Gashole Emeritus
Originally Posted by SKINNEDR View Post
Check with the SPF website (Forum). Those guys have a totally different perspective about PE.
Dex....
Having been a past member on SCOF for several years, Dex's statement is true BUT it's important to be "unbiased" and the conflicts between the SCOF participants isn't always the case. If you have a problem with a product and approach the owner with guns blazing and demands, you'll be met with an appropriate response/reaction. If you approach the owner trying to "mutually resolve" the problem, the reception and results will be favorably productive.
First time cobra owners don't have the historical privilege of knowing the "balanced sides" of all engine builders, so weigh the information with a jaundiced eye and be specific on what you want and expect out of the engine you're having built. Forget the testosterone, egotistical approach of wanting the biggest and baddest engine built and installed. Just because you're fortunate enough to afford a high end, big horse powered car doesn't qualify you as an experienced competent owner/driver. Be sensible and do your homework. Talk to several engine builders, visit their shops and check out owners on both sides of the fence as to quality of build and after install service.
My experience with Eric has been exemplary and I did have one custom built engine that melted down due to a building error BUT that wasn't Eric's fault, it was one of his workers (Jerry) and unfortunately one of the guys that subsequently purchased and lost Competition Motorsports (while dragging the established good reputation through the dirt) during Eric's brief hiatus. Eric corrected the problem and that engine is still running strong 8 years after the build.
Best of luck, they're wonderful cars and will provide more memories and smiles than you ever imagined.
DDS/The First Edition
"In debates on ethically contentious issues, it is never wise nor polite to deride or belittle another person's delusion."
