Old 08-16-2008, 05:42 PM
fkemmerer's Avatar
fkemmerer fkemmerer is offline
Cobra Make, Engine: ERA, FE BBF
Originally Posted by reed1951 View Post
Hey guys, I have a hot rod truck that weighs about 3400 pounds and am wanting to use this 408 stroker from Keith Craft:
http://www.keithcraft.com/engines/40...te_Engine.html
Truck will be a street driven truck. I have a c4 trans and 9 inch with 3:50 gears
What size stall converter should I use?....this engine makes 485 pounds of torque at 3200rpm so I figured I might even be able to use a stock converter
Where is the peak torque for the motor? From the sounds of it, its probably down pretty low. I'd use a mild stall speed converter. Something around 3000 PRM.
