Old 08-17-2008, 10:57 AM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
You can work out the max cam specs with a little patience. Remember that the valves also can only be pushed sofar before you get coil bind, Max Valve Lift ,the head manufacturer will give you those specs (You need 0.060 clearance between the coils) although I do run mine a little closer. The rocker ratio is the next thing, Divide the max Valve lift by the Rocker ratio and that will give you the max cam lobe lift. A solid roller cam with rev kit and roller rockers works good.If you would like to email me I can help walk you through the process.
John
