Old 08-17-2008, 05:34 PM
428street's Avatar
428street 428street is offline
Cobra Make, Engine: BRG ERA street car w/428 PI, Sunburst wheels, undercar exhaust, original interior, no philips head screws!
Default Rear mount battery ?
I'm in the process of installing the cabling for my rear mounted battery. I checked out the entire process on the website and it looks fairly straight forward. I do have two questions.
1. The directions state to connect the black ground cable with the battery terminal on the end directly to the frame. I assume you have to drill a hole into the frame. I did not see one pre-drilled.
2. There is a black ground cable that came with my set. Not sure were that goes. If you connect the battery ground cable directly to the frame and then ground the engine via the tranny ground strap per the manual what is that second ground cable used for? This cable has two round eye connectors attached to it.
