Old 08-18-2008, 12:04 AM
Barnsnake's Avatar
Barnsnake Barnsnake is offline
Cobra Make, Engine: LoneStar LS427 , 427 Windsor
Where are you measuring your oil pressure? Two filters in parallel should reduce the overall filter resistance. If you are measuring upstream of the filters, the pressure may drop. If you are measuring downstream of the filters, it should go up (a little).
If your filters are in series the opposite would be true. I don't believe I would want two in series.
Jim
A Gnat! Quick, get a sledgehammer!
