Old 08-20-2008, 07:37 AM
Archrms's Avatar
Archrms Archrms is offline
Cobra Make, Engine: Superformance SPF#2572, 427 S/O 2X4
Default It Lives!!!
I went through everything again this morning after thinking about this all night. I double checked everything again, when I noticed that the front carb fuel bowl level was lower than it should be. While trying to adjust it, it started leaking from the screw, even after I locked it back down. Took carb off and pulled bowl off. Sure enough the float tang was bent. I bent it back in place, eyeballed an approximate float level, and reinstalled carb. It fired up after a few tries. Went through and adjusted all float levels with car running. Still trying to clear my lungs from all of the exhaust in the garage , but it was worth it.
Hopefully this solved the problem. Thanks to all for your input and suggestion. I will keep you all posted on final outcome.
Peace through superior firepower...or is it horsepower? Either way, more is always better!
