Old 08-20-2008, 05:49 PM
rokndad's Avatar
rokndad rokndad is offline
Cobra Make, Engine: CSX 4758, CSX 381 Keith Craft 482 w/ Weber 48 IDA's
Eric,
I have also been fascinated by the Dynatek system, and had started a brief dialog with the Dynatek Racing folks, but have not made the plunge yet since they said they are still "tuning" things up for the FE (see Sept 2008 Kitcar Magazine article....thanks Rodknock!!).
As I understand it, their FE intake manifold, eight injectors (four housings), linkage, ECU and wiring is around $6500, plus high pressure fuel pump, return lines, set up on a dyno which are extras.
Please post photos and keep us updated on your build. I think my KC FE may be close to what you're having built so it may be able to use the same set up. BTW, is Keith buying the unit for you? You're going to be happy with KCR.
