Old 08-23-2008, 10:57 PM
legenmetals's Avatar
legenmetals legenmetals is offline
Cobra Make, Engine: contemporary(2) one with 427 sohc and one with 427 center oiler
I changed back to the original Jag rubber style steering rack mounts.I switched from radial TA's to Goodyear Billboards and the vibration was very bad.The Borgesen steering shaft isolator could not get the job done.With the rubber mounts I feel a little vibration until the tires warm up. As a note,the goodyears rubbed the rear inside fender flare lip (I have the wider rear axle on this car).The fix was a set of Qa1 adjustable coil overs with the original Koni coil springs.The car now rides better and looks great with the Billboards.
