Thread: brakes
Old 08-24-2008, 02:02 PM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
Vaccum pump.
You remove the bleeder and put some thread sealer on it. Make sure the bleeder will seat okay and the hole is open.
Connect the vaccum plate to a mason jar. Run one hose to the vaccum pump and the other to the bleeder nipple. Pump out the air. Shut the bleeder when you see a steady stream of fluid.
Hope this helps.
BTW, Harbor freight tools has the vaccum pumps for $20.00. If you can go to a store, it is PN 92474.
