Thread: rear main seal
  #21 (permalink)
Old 08-24-2008, 08:24 PM
Keithc8 Keithc8 is offline
The one peice seal has help a lot. We check this on the dyno when we run the engines and we have some guys that call with a leak and we did not have it on the dyno. I have some guys over fill the oil pan, have a problem with the oil line at the front and it run back along with a few other things. I always try to oil dye the engine in the car if I have a leak to see if I can find where it is leaking for sure. I have evn had the transmissions leak and run out the bell housing a fool you. Good luck, Keith
Keith C
