Originally Posted by Tom Kirkham
Most of the cars to maintain the look of an original Cobra are not running a vacuum advance. If the driver is smart enough not to floor the throttle at low RPMs, fuel economy, throttle response, under hood temps, can all improved.
Tom, that explains it, this theory might not work with my KC Nascar based engine being a bit bigger in the ports and camshaft, I dont envisage it will have much below 4000rpm, however I have been told KC does a good job of producing engines that pull quite well from 2500rpm up. Is there a tendency to have it coming in higher up on less streetable engines, as a 427 which I have owned pull better down low?
