Old 08-26-2008, 05:39 PM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Originally Posted by Great Asp View Post
Your crusing rpms seem spot on for your arrangement. I will have the same, but I would rather have like 2200 rpms for the highway at 70 mph
Really, If they would have had the 3:73 for the rear, I would have ordered the .64 5th. Go to the Second Strike Calculator and play around with the rear gears and the 5th speed and you will see what I mean. With 3:73's, and a .64 5th you get a nice cruising speed/rpm ratio.
http://www.secondstrike.com/Technical/GearCalc.asp
Thanks for posting!
E
Try 3.31 with the .82 5th- about perfect
Replica is not a dirty word.
