Old 08-27-2008, 03:34 PM
400TT's Avatar
400TT 400TT is offline
Paul, how about considering just narrowing the track of your CR? That way you can use cheap quality off the shelf pin-drive wheels from someone like Vintage Wheels US or someone else if you can manage their backspacing.
I just recently made pin-drive hubs for my Jag front end. By fitting larger brakes I was able to move my wheels in 30mm each side. I used 310mm rotors, 2 piston PBR calipers which all fitted under 15" wheels.
Then see what's involved in narrowing that rear end.
I expect Mike can explain the pros & cons of such work on a CR.
At least by narrowing the track you won't have the problem of the spinners sticking out like a Roman Chariot.
Just a thought, although maybe you have already considered this option.
www.absolutepace.com
