Old 08-28-2008, 04:57 PM
Donald Campbell Donald Campbell is offline
Originally Posted by MEATMASTER View Post
When you say you "stripped" the engine, are you talkin about taking off valve covers, intakes, distributors and oil pans? Or are you talkin about taking the heads off and the internals out and stripping the engine to the block?
More details and less generalisms would help. thanks
MEATMASTER
We were told that the replacement motor would arrive complete and tested. The replacement "crate motor" arrived incomplete and untested, and with used and or damaged parts. There were missmatched and missing fasteners throughout. We had to take off or swap out valve covers, carburator, turkey pan, starter, distributor, fuel lines, oill and coolant fittings, water pump. The original motor was installed by Unique in a gloss painted engine compartment that was perfectly detailed. Pulling and replacing a 427 without damage in a cobra is a chore. The headers were custom built for the first block and do not now fit the replacement motor.
