Old 08-29-2008, 01:34 PM
JayBar's Avatar
JayBar JayBar is offline
Cobra Make, Engine: BDR#078,408 Dart Block, TKO 600,Indigo Blue, White Stripe
Send a message via Yahoo to JayBar
Neutral
Originally Posted by native1 View Post
Just thought you all might want to know. When the engine came from Roush the dyno tag on the 427 srtw read 510hp/528tq out of the crate. Then I put on the vic jr. and the 950cfm carb. Don't know were crankshaft hp is now. With the latest rwhp numbers, I would like to think it is around 540hp. I am very happy with the srtw, it pulls down low and up high.
I have a Dart block locally built 408 with AFR heads H beam rods forged steel crank, tirck flow stage III cam. Petty much the same as a Roush but a lot less money. Anyway I dyno'ed at 401 hp at the rear wheels with a dual plane manifold with a HP 750 carb. My engine builder said if I really wanted to make some power I should go with a Victor Jr and a HP 950 carb. I did and gained 25 RWHP.
So your estimate of picking up 30 hp at the crank with the manifold and carb are right on.
Yea I know there are people out there saying I have over carb'ed it. But, you know what? It pulls like fuel injection. I can be lugging along at 35mph in 4th gear (3.73rear) and punch it, and it pulls no hesitation, just pulls.
I would not have believed it but I thought I would try it and it worked. Down side is 10mpg, but for the amount I drive it on the street it doesn't matter.
JayB
Jupiter, FL
