Old 08-30-2008, 01:20 PM
Chakaron Chakaron is offline
Cobra Make, Engine: Superformance #1850,
Hi Pete,
The slave cylinders on the Superformance need to be changed out from time to time. Especially, if they have set for a whlie without being used. It's a simple deal to change...two bolts and one line. You'll need to bleed the air oot when finished.
Several vehicles use the same cylinder so your local parts store should have a new cylinder. I've got the part number somewhere..if you can't find a cylinder send me a note and I'll get the part number for you.
Good luck!
Chankaron
