Old 08-31-2008, 08:58 AM
Rob. Smith Rob. Smith is offline
G'day Bryan,
Here's my 2 bobs worth...I'm not sure about holdens and v6 setups but if they have individual spark plug wires . Have the engine running,idle is good enough, and pull the plug leads off one at a time and listen to the idle "tune".. If the engine runs rougher while that plug is disconnected. That plug must be OK. If the idle "tune" doesn't change You have found the problem cylinder and plug.
Obviously you have found the suspect plug already so try to "jump-short" the crook plug lead. I mean you should put the offending plug lead. Close to..but not touching, an earth and see if you get a spark. if you do get a spark you've got a dud plug. If you don't get a spark...The lead could be crook. Swap a couple of leads around and test again. If that doesn't work you've got a crook coil. (Here I'm guessing. Is there individual coil packs... one of those could be the problem).
Only a suggestion. Not questioning anybodys' auto electrical / mechanical knowlege.
Good luck,
Rob Smith
