Old 09-01-2008, 04:53 AM
acecob's Avatar
acecob acecob is offline
Default Quick and easy
Rather than playing with high voltage leads try taking the wire plug off the injector on that cylinder you can even go through each one at a time to see the variation on each Cyl. when you find a cyl that isn't working pull off the lead and check it with an ohm meter. If the leads are ok give it a quick compression test maybe it's dropped a cyl. if they are ok it could be your coil pack,
It also sounds Like it could have a vacuum leak around that Cyl check that all your vacuum hoses are on as well
If all that fails Drop a ford engine in it should solve ur prob
serious about the first bit though
