Old 09-01-2008, 07:37 AM
TWOOD TWOOD is offline
Cobra Make, Engine: Classic Roadster II, 351 windsor, Tremmec T-5
DV, I sent photos of the only two ways to position the brackets. Which one was wrong?
OK, they are identical brackets, but is the same part supposed to be used on both the left and right side?
If the ears side of this angle bracket is facing the engine (inboard), and point upward then the taller, of the two, ears will be to the front of the car (on the right side) and the taller ears will be to the rear of the car (on the left side).
This changes the angle the the control arm relative to horizontal. Tilted up on one side of the car and down on the other. And definitely not parallel to each other.
This does not seem correct. If the two brackets were mirror images of each other(two different parts), then things make more sense.
I be-laboring this issue, I'm sure. Sorry, everyone.
Does anyone have a photo of these brackets installed?
Are these two brackets suposed to be identical or should ther be a left and a right?
DV, I replied to you via email, in greater detail.
What a easy thing for CRII to have done, if they simply had supplied a basic drawing, on a single piece of paper, to accompany the parts.
