Old 09-01-2008, 08:22 AM
wtm442's Avatar
wtm442 wtm442 is offline
Beam Me Up Scottie
Originally Posted by Power Surge View Post
Remember that the DOT is on both sides of the tire, but it's only a partial number on one side (the partial side doesn't have the date portion) and the full number on the other side, so make sure you look at the right side.
Usually the date code is on the inside of a mounted tire.
Many "experts" say the shelf life of a tire is 6 years (Ford), but others say you should replace a tire after it is 10 years old (Bridgestone). Others say 5 years if you are in a hot climate and ten years if you are in a cold climate.
All I know is that my SPF was manufactured in 2001, so the tires are at least 7 years old, and will be replaced this winter.
Here is good explanation of date codes
http://www.tirerack.com/tires/tirete....jsp?techid=11
Warren
