Old 09-01-2008, 09:05 AM
Bobcat Bobcat is offline
Frank ... just went into the garage and measured as close as I could to where you measured . Passenger side is 2 1/2 " .... maybe a 1/16" over that , measured to the center of my tire and the Driver`s side is right at 2" , also measured to the center of the tire ... wheels straight ahead. I went to the 245`s in the front because Avon doesn`t make a 235 and I really wanted to use their 15" tire . I checked with Bob before buying the tires and he went into the shop and did some checking and that`s when he told me I might have to do some trimming on a full left turn if the suspension was in full droop .
You said when you put the car on the ground it didn`t make any difference , but an engine will add about 600# or more .... talk to Doug Monday and he may have some more ideas .
I`ll try to get some pictures of both sides for you , but I just got back from my Father in Law`s funeral and aren`t back up to speed yet .
Good Luck ,
Bob
