Old 09-01-2008, 09:37 AM
Johnnyquest's Avatar
Johnnyquest Johnnyquest is offline
Cobra Make, Engine: CSX4853, Roush 451FE
Default FFR MKII 3334 For sale!
I am putting up my Factory Five Racing MKII #3334 for sale!
I have listed it in the main classified section.
$31,000
Factory Five Racing #3334k
Engine: 351 Windsor/410h.p. Balanced & Blueprinted- 2/24/04 Completion
http://www.enginefactory.com
Edelbrock RPM Aluminum heads
Ford Motor Sports Natural Finish "Cobra Valve Covers"
Crane High Output Camshaft 234 duration .520 Valve Lift
Comp Cams Magnum Roller 1.6 ratio rockers
Holley 650 double pumper zinc coated
Edelbrock Performer RPM Dual Plane intake manifold
March Polished Under drive pulleys
Chrome 100 amp one wire alternator
FFR 4 Port Ceramic Coated Headers and Sidepipes, Metal Gaskets
Chrome Dip Tube and Dipstick
Natural Finish "Cobra" Oval Air Cleaner
Chrome Front Sump 5 Quart Oil Pan
Fortes Aluminum Reservoir Tank and Overflow Tank
Fortes Adjustable Clutch Quadrant
Shelby American VIN plaque
Heater Hose Bypass
MSD 6AL Electronics
Accel High Performance Billet distributor
Accel Silicone 8MM Plug Wires
New AFCO aluminum radiator
FFR Oil Cooler with Braided Lines AN fittings, Canton Remote Oil Filter Setup
Original Twin Pusher fans
Authentic Alum. Fan Shroud Cover w/Original Radiator Bracket
Running Gear and Internals:
Tremec TKO 5-speed Transmission, 3.73 gears in 8.8 rear
Weber Racing Clutch
Pro-Shox Coilovers
FFR Upper Control Arms
Maximum Motorsports Lower Control Arms( w/spherical bushings at axle )
Adjustable Front Upper A Arms
Ford Lower Control Arms and Bushings
Authentic PSE Engineering 15", 4 Bolt Halibrands
Nitto 555R Extreme Drag Radials 275/50/15 V rated directional tires at rear
Yokohama Avid S2Db 225/60/15 V rated directional tires at front
Russell Braided Stainless Steel Flex Lines ( all three )
Flaming River Steering with off-set solid bushings ( Breeze )
Rag-Joint Eliminator
Tubular Chassis with 6061-T6 100% Aircraft Aluminum Riveted Outer Skin
Interior/Electrical:
Autometer Gauges set in Authentic Shelby Cobra Street Layout
Authentic Classic Seats
Optima "red top" battery with custom aluminum billet hold-down tray
Full Insulation Under Carpet
Aftermarket Gas Pedal Assembly
Dual horns
Mike Everson parking brake, belt trim rings, roll-bar bezels
Professionally "prepped" wiring harness by Rob Weatherbie
Original Lucas Wipers
Original Lucas Lighting and Switches
Original Windwings
Original Sunvisors
Competition Electrical cut-off switch with Original decal
Chrome fire extinguisher
Simpson racing 4pt. belt setup
Carroll Shelby Signature on visor
Exterior:
Viper Red, Professionally Prepped by Dartmouth Collision
Original Overiders and Bumper hoops
Original Chrome Roll Bar
Original Cobra Badges, 427SC Emblems
Original Beclawat Window Emblem
Original Alum. Side Quick Jack Covers
Original Hood racing pin setup w/optional Original hood hinge w/Prop rod
Original Trunk Hinge setup
Titled as 2002 Replica Model 1965
Estimated Performance: 0-60 3.7 seconds, 1/4 mile 11.7 @117 mph Top speed 151 @ 6000 Skid pad: 1.02 g's
This is a USED vehicle and does have imperfections from road conditions and normal use. Inspections are incouraged
68 Hertz~09 KR~FFR Coupe~CSX4853
