Old 09-01-2008, 12:19 PM
Rick162's Avatar
Rick162 Rick162 is offline
Cobra Make, Engine: Kirkham 427SC, 427 SO from the Fliptop
Smile
We hope you like them. Thanks for the Compliments
We realize that we are not the cheapest you can find.
The HM Logo red line GT 40 Tach Set contains (8) Gauges, one more gauge (the Trans temp) the HM set was designed for the GT40 dash vs the (7) Gauge reverse speedometer set for the Cobra.
If you have a few bucks into your engine, you probably want the most accurate gauges you could find, (especially at critical oil temp and water temp zones, found often at the edge of your gauge) to protect you investment. I think 270 degree sweep vs 90 degree sweep is really nice when driving.
The gauges all have microprocessor controls (a computer chip in each gauge) and very very high end sensors which puts their costs of good sold much higher, than say, traditional Cobra gauges. Using higher end components, with advanced processor design we are able to give you dead nuts accurate readings in your gauge. We are so confident that we warranty your gauges for your lifetime.
Remember these cars generate a tremendous amount of heat and vibration so close to the back of the dash panel. Our thick (advanced material) cases and spin lock system protect your components quite uniquely. Our bezels are not the crimp-on plastic that eventually de-laminates, ours are solid aluminum after all....... you usually get what you pay for.
We have been working and finally finished the 3 3/8 Gauges for the FIA 289. More options for our Cobra Community. Just a note ....we also make the BRE line of Gauges for Pete Brock's Coupes. These have a programmable span shift light with peak recall built right into the vintage style tach.
Just More options for your ride...... to make it your own
