  #23 (permalink)
Old 09-01-2008, 05:42 PM
tcrist tcrist is offline
This is the picture
Tom,
Look at the first picture that you send me of the a-arms,spindle and the bracket. If you take picture #3 here, showing how the bracket will not line up with the bolts, and turn it around 180 degrees. That is what it shows in the picture. I agree that it looks like you were sent 2 of the same bracket and you might supposed to have a right and left.
These brackets would bolt up with the single hole to the frame and the leg of the angle (that bolts to the frame) goes towards the engine. The a-arms would then bolt to either of the 2 remaining holes and then the adjustment would be by using shims between the a-arms and the angle (like a chebbie). Add the picture of the assembly that you sent me to your post. I think that will help others see what I am seeing.
This is just my opinion of course.
Terry
Last edited by tcrist; 09-02-2008 at 08:53 AM.. Reason: added picture of assy for TWOOD
