  #24 (permalink)
Old 09-01-2008, 07:15 PM
gman gman is offline
Cobra Make, Engine: A&C 460
The control arms are not supposed to be parallel with the ground. They lean from high in the front to low in the back. This is for anti dive, and is correct for Mustang II suspension. I believe you have two brackets for the same side.
Gman
Also the last photo of the frame is correct. The bracket does not allow adjustment. You must use alignment shims between the bracket and the control arm.
