Bob Putnam
I built a box similar to the one in the photograph. I put a 1/4" foam padding on the outside of the box to hide the sharp edges and then covered it with vinyl to make it look like an extension of the dashboard.
Only thing I did differently was building the box as wide as the tunnel itself, so I was able to install the two speakers in the same box. Came out loooking good, and I will be able to remove the entire setup within minutes if I wanted to.
Few questions.
The radio calls for the following coonnections.
1-12V supply that is energized ALL THE TIME
2-12V supply that is energized IN THE ACCESSORY POSITION of the ignition key switch.
3-12V supply from the ILLUMINATION SIGNAL.
Since you are far more familiar with the schematics can you specifically tell me where exactly to connect the above three wires. Giving me the numbers as depicted with the wiring harnesss would help a lot.
I think I figured out the (-) GROUND wire all by myself!
TURK
