Old 09-02-2008, 08:48 PM
Bobcat Bobcat is offline
Guys ... I would like to clarify what appears to be an impression that I am having major problems with front tire location in the wheel wells/inner fender lip . I decided to go with the Avon 245-60/15 front tires and had ERA run a check to see if there would be any interference issues on my 427 SC with those tires . I was told that there might be some interference with the inner lower lip on a full left turn at full suspension droop on the driver`s side .... which there is , but not a huge problem . I get a full turn to the left of the steering wheel before the tire contacts the inner lip . I feel that if I forced it , it might go the rest of the way ... but I won`t . If you look at the tire relationship to the wheel opening closely ( at least on mine ) at full suspension droop ( my car isn`t on the ground yet ), the tire is at the widest point on the circumference . I feel that when the engine is in the car , suspension and alignment set , that the wheels may go far enough into the wheel cutout due the weight , that I may clear without any surgery to the lip .... but again , I knew this going into it as I really wanted to use the 245 front tires . If the problem still exists , then I will just trim the inner lip .
There are no clearance issues with a right turn and I have about 1/8" between the tire and the inner lip on the passenger side .... which will increase when the car is on the ground .
I really can`t think of any circumstance where I will have the suspension at full droop and full left turn while driving .... or if I do , I`m probably in deep you know what .
