Old 09-04-2008, 08:47 PM
xlr8or's Avatar
xlr8or xlr8or is offline
You might want to measure from the pilot bearing to trans mounting surface on the bellhousing and compare that to the length of the shaft from the end of the splines to the mounting surface. This will verify the need for the space as well as how thick of a spacer you need. With the standard shaft and a lakewood housing it should be 1/2".
